Empty response from Zabbix Agent at [IP]. Assuming access permission problem.
  • jessie
    • Aug 2018
    • 13
    I would appreciate any help with this problem. I don't know exactly what am doing wrong.
    Who ever has had similar experiences, please how did you rectify this problem.
    thanks in advance!
  • Atsushi
    • Aug 2013
    • 2028
    Please check the setting of Server in the Zabbix Agent configuration.
    If the IP address of the Zabbix server is not registered in the "Server" setting, it is judged as a request from an unauthorized server, and the response is empty.
    • jessie
      • Aug 2018
      • 13
      Hello Atsushi and thank you for responding to me post!
      Please forgive my ignorance but I would like to be clear on this.
      Do you mean that I should register the IP address of the Zabbix server in my PC in the Zabbix agent configuration file downloaded into my HP server?
      Please clarify with photos if possible.
      Thank you!
      • Atsushi
        Atsushi commented
        It is necessary to describe it in the configuration file for Zabbix agent installed on the monitored server.
        ex.
        /etc/zabbix/zabbix_agentd.conf
    • jessie
      • Aug 2018
      • 13
      Thank you for the helpful advise!
      I did as you said and its fine now.
