No web-interface on zabbix
  • goker
    • Sep 2018
    'sdone
    yum install zabbix-server-mysql zabbix-web-mysql zabbix-agent
    status: wonderful and the server and the agent workin
    selinux&firrewall re off
    index.php entry point. It prescribed the usual php text-worked, but the Zabbix System itself is not.
    log:
    can not send list of active checks to "127.0.0.1": host [Zabbix server] not monitored
    ths
  • Atsushi
    • Aug 2013
    • 2028
    What OS are you using?
    Please give detailed information such as distribution and version.
    • goker
      • Sep 2018
      distrib. centos 7
      • Atsushi
        Atsushi commented
        Is httpd running?
        How will it appear when accessing http://<zabbix-server ip>/zabbix/ ?
        If nothing is displayed, is the error log(/var/log/httpd/error_log) outputted?
    • goker
      • Sep 2018
      1 - yes
      2- internal server error , but as i sad above "index.php entry point. and the usual php text- it works, but the Zabbix System itself is nt."
      3- it says "PHP Parse error: syntax error, unexpected '$fields' (T_VARIABLE) in /usr/share/zabbix/index.php on line 41" is this a Reg.Form?
      • Atsushi
        Atsushi commented
        Please tell me the version of PHP you are using.
      • goker
        goker commented
        zabbix 3.4,
        Apache/2.4.6
        PHP 5.6.37
        centos 7
    • goker
      • Sep 2018
      ths.for yo helpa
      • Atsushi
        Atsushi commented
        If you do not use the OS standard package, it is possible that the PHP environment is not set up properly.
        Please make sure PHP is functioning properly by using phpinfo().
        For example, please place the following file in the directory where the Zabbix front end is located and try access.
        phpinfo.php
        <?php
        phpinfo();
        Is the version that you anticipate running on PHP version?
