Multiple active agents in same host machine
  • shoraib
    • Sep 2018
    In my environnement, we have have four different java applications installed in the same Websphere Enterprise Server using the same IP Address. All the four applications use different active agents. Each agent is defined by a different configuration file with unique hostnames. On zabbix side, we use these hostnames to monitor activity on java applications. Unfortunately the configuration works for the first node but not for the other ones. I'm unable to find any details for this type of configuration. Any precious advice will be grateful.
