Hi ...
I'm hoping someone can point me to a doc / example of doing this, since I'm drawing a blank ... I've searched Google, as well as gone through the various templates on share.zabbix.com ...
I have a Discovery rule that gets me a list of databases, that works fine ... that was easy. What I want to do next is to monitor table bloat ( postgresql ) on the tables within the database, so I created an item that queries the database for all tables in a database, and their bloat:
What I want to do is create a DEPENDENT ITEM that takes that one query / item and fans it out to multiple items, which I believe is possible ... but I'm not sure how to form the dependent item ... I did what I thought made sense, but when I try to add it tells me:
I did it first where my dscovery rule was the above userparameter and then an item prototype for getting the bloat, but having zabbix-agent query the database 900 times a minute continuously when I *could* get the same out of one query and letting Zabbix use that one result would be so much more efficient ...
Does anyone have a sample of doing something like this, with an SQL query, that I could look at ... or some advice on a better way to do it ... ?
Thx
UserParameter=pgsql.table.bloat.discovery[*],/bin/echo -n '{"data":['; psql -qAtX -f scripts/get_table_bloat.sql d4tf1q7m4n8dr2 | while IFS="|" read table tbloat wastedbytes; do /bin/echo -n "{ "{#TABLENAME}": "$table", "{#BLOAT}", "$tbloat", "{#BYTES}", "$wastedbytes"},"; done | sed -e 's:\},$:\}:'; /bin/echo -n ']}'
- Invalid key "{#TABLENAME}" for item prototype "{#TABLENAME} bloat ( % )" on "PostgreSQL Simple Template": incorrect syntax near "{#TABLENAME}".
Thx
