Trigger with time range
  • luissuez
    • Sep 2018
    • 11
    Hello everybody
    I'm new with Zabbix and I have a little issue. I set ODBC in order to create som sql query. Those query check some value and the result is triggered if wrong. All fine. But now I have a new check to set that I only can check between 14h00 and 15h00.
    So, acordng to some posts I use this sintaxe in my trigger:
    {Zabbix server:db.odbc.select[GesIntel,ESTTEL].last()}>0
    This trigger works but I need to add the tiem range.
    I try like this:
    {Zabbix server:db.odbc.select[GesIntel,ESTTEL].last()}>0 & ({Zabbix serverroc.num[ntpd].time(0)}<153000 | {Zabbix serverroc.num[ntpd].time(0)}>140000)
    This sintaxe is wrong because I have a sintaxe error... Someone can help me
  • kloczek
    • Jun 2006
    • 1771
    Look on "time" function on https://www.zabbix.com/documentation...gers/functions
    • luissuez
      • Sep 2018
      • 11
      Hi , thanks for the help... But I'm not able to resolve this with this link, Could you please post an exemple to get my trigger with a time range?
      Thanks in advance
      • Anth(0)ny
        • Jul 2015
        • 42
        expression with additional time range from 1 to 2 hours
        ... and ({....time()}>010000 and {....time()}<020000)
        • luissuez
          • Sep 2018
          • 11
          Hello
          ok, so I try this code in the trigger:
          and ({Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}>010000)
          and ({Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}<030000)
          but, it fails..
          The error is:
          [CODE]Incorrect trigger expression. Check expression part starting from "0 and ({Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}>010000) and ({Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}<030000)"[\CODE]
          Thanks a lot
          • zux
            • Sep 2018
            • 97
            I think you have some syntax errors there. This one works for me:
            {Zabbix server:system.cpu.load[].last()}>0.5
            and {Zabbix server:system.cpu.load[].time()}>170000
            and {Zabbix server:system.cpu.load[].time()}<180000
            • luissuez
              • Sep 2018
              • 11
              Hello Zux
              thanks for your assistance
              I change my code with yours:
              [CODE]{Zabbix server:db.odbc.select[GesIntel,ESTTEL].last()}>0
              and {Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}>130000
              and {Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}<150000[\CODE]
              But I still have the same error.
              My zabbix version is 2.2
              • zux
                • Sep 2018
                • 97
                First of all - I would upgrade
                Second, start by looking at the documentation for you version, there are changes in newer releases:
                https://www.zabbix.com/documentation...ers/expression
                I don't have 2.2 to test on, but it looks like the function "and" was not implemented, the examples at documentation mention "&"
                • luissuez
                  • Sep 2018
                  • 11
                  Zux
                  you're right
                  After checking the doc I put this:
                  & {Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}>130000
                  & {Zabbix server:db.odbc.select[GesIntel,ESTTEL].time()}<150000
                  and now it works fine.
                  Thanks all for the assistance
                  Cheers
