changing templated item fails
  • coffeejunkie
    • Aug 2018
    • 11
    Hi Guys,
    i have a host group of around 450 servers. To each of this hosts the same template is assigned.
    The template holds 80 items. 70 of them are disabled.
    I'm trying to modify some of the items - Update Intervall / storage period / history period or even add a new item.
    On clicking "OK" in the same second I get an empty webpage as response and the items are not updated/modified
    Any ideas?
  • DmitryL
    • May 2016
    • 278
    Check your web engine (apache/nginx) error_log and based on error lines that you will find there, adjust php parameters.
    • coffeejunkie
      • Aug 2018
      • 11
      perfect - that did the trick.
