monitoring->graphs for windows is showing only "C:" drive not others
  • katka06
    • Sep 2018
    For windows agent monitoring graph, I can able to see only "C:" drive details it is not showing other drives which are there like "E:", "U:". Can anyone help here?
    what option should i select for showing graphs for other drives on windows - I am using "template OS windows"/
    Thanks, karthik
  • Atsushi
    • Aug 2013
    • 2028
    If you are using a template, Zabbix should use the LLD feature and monitor items for automatically mounted disks should be set up.
    However, since it is filtered by the file system you are using, check the regular expression to see if the type of file system you are using is registered.
    • katka06
      • Sep 2018
      Yes. Got it. Thank you.
