Vmware Vcenter 6.7
  • aros
    • Sep 2018
    Vmware Vcenter 6.7
    Hello
    I am installing a 6.7 vcenter to replace my 6.0 vcenter.
    I have a problem with supervision. The default templates for discovering ESXi and virtual machines no longer work.
    I am in version 3.4.8 of Zabbix. Is an evolution of vmware templates planned?
    Thank you.
  • aros
    • Sep 2018
    On zabbix interface I have : SSL connect error
    I dont have this error with vcenter 6.0 and same CA cert.
    • jackhuang
      • Jun 2017
      I have the same issue on vCenter6.7. Do you have solution on it?
      • lcarangelo
        • Apr 2017
        Hi, I'm having the same issue using Zavvix 4.2 and vCenter 6.7.
        Did you fix it in some way ?
        Please let me know
        • lcarangelo
          • Apr 2017
          Problem is related to SSL that is not supported anymore by vCenter 6.7 (olny TLS).
          It seems that Template VM VMware does not negotiate TLS
