Forwarding metric value into a tag
  • mbribeiro@gmail.com
    • Jun 2018
    • 13
    Hi, we are receiving a metric via zabbix_sender and it is a string (just like a line from a log). We are wondering if we can have part of this string or the entire string stored in a tag (in case of a trigger).
    Our first try was using {EVENT.STATUS} (assuming this macro would contains the string) but this macro was not expanded into the string.
    Is there a way to have the metric value stored into some field in the case of a trigger event ?
    Thanks in advance.
