Hello...
I have a problem with write a cluster into elasticsearch from my zabbix server.......
I've tested those points:
1- elasticsearch cluster don't support VIP (virtual IP)
2- i use a DNS to put two hosts and use as domein into my zabbix server configuration,
this is my DNS configuration
elastic1:192.168.10.12
elastic2:192.168.10.101
$TTL 604800
@ IN SOA ns1.elastic.lan. admin.elastic.lan. (
19990811 ; Serial number
3600 ; 1 hour refresh
30 ; 30 seconds retry
172800 ; 2 days expiry
43200 ) ; 12 hours minimum
@ IN NS elastic.lan.
@ 5 IN A 192.168.10.12
@ 10 IN A 192.168.10.101
#Server Zabbix config
HistoryStorageURL=http://elastic.lan:9200
#Web Zabbix config
$HISTORY['url'] = 'http://elastic.lan:9200';
this configuration works, is switching between two ips, but zabbix server always try to write in both server , it changes alone in a several times.
this is my question...do you know some workaround can I use for fix it??
and in zabbix version 4.0, will be posible to put in my zabbix server configuration something like this:
HistoryStorageURL=http://host1:9200, http://host2:9200]
please help me and thanks for your help!!!
$TTL 604800
#Web Zabbix config
