Log Item Help
  • TheCookieMonster
    • Jul 2017
    • 48
    Log Item Help
    Hey,
    I have a log item set up as follows:
    My questions are:
    1) The Mode I have set to Skip, expecting only new log entry's going into the log from this point on wards that contain BA2940 to be returned, however historic log entry's are also being returned, am I misunderstand what Mode and Skip does?
    2) An example log entry is: 02/10/18 01:23:56 Logger: latest BA2940 id 250903
    Have I set up the Log time format correct, should I expect to see if in the Local timeon the latest data values for this item, or am I also misunderstanding the point of filling this out?
    3) Every so often, in the zabbix log on my host, I see the log entry: 6952:20181002:112120.276 convert_to_utf8() in_size:108 encoding:'UTF-8' codepage:65001
    What does this mean? Do I need to change something?
    4) Every so often, in the zabbix log on my host, I see the log entry: 6952:20181002:112159.395 send_buffer() now:1538475719 lastsent:1538475715 now-lastsent:4 BufferSend:5; will not send now
    Once again, what does this mean? Do I need to change something?
    Cheers for the help guys and helping me to learn and understand this better.
