How to check a specific network folder
  • vega2511
    • Mar 2014
    • 11
    I want to monitor a specific network folder and display the file names.
    example folder path: D:\Push\Teletext\blabla\outbox\page
    We generate pages and if the publish is OK the pages are disappearing from the outbox. And let say by a time interval of 10 seconds we want to check if the publish is going well.
    Can someone tell me how to set up something?
    Can you do this without scripts and only by adding some lines in the agent config file and how to make the data visible in the Zabbix frontend (item)?
    Many thanks in advance .
  • coreychristian
    • Jun 2012
    • 159
    Well to start, you will run into problems with the zabbix service being able to see your network drive.
    Already spoke a bit about that in another thread.
    For the time stamps you might be able to use 'vfs.file.time[file,<mode>]' or something similar, or if you can get an output in a single command use the 'system.run[]'
