Hi All,
Just wondering about the export function for Zabbix maps and just wondering if anyone had luck with exporting the maps to other 3rd party software and if so, which software was used to view these exports? Is there any plans to have compatibility with MS Visio or would one be better off just not using this map function.
R
R
