Monitor Memory, CPU load for Windows specific application e.g. Chrome, other .exe
  • sage12
    • Sep 2018
    Kitchen kitchens play a very important role in human life because kitchens are the heart of the home, so choosing the smallest details contributes to that heart. In that sink close to the owner, so choose a good sink, porcelain sinks, stainless steel or stone.
    Sink stainless steel
    The stainless steel sink is a multi-user interior because it is highly durable, easy to clean and suitable for many interior designs. Using stainless steel basin is also very convenient, easy, prices range from a few hundred to several million. This is a common kitchen furniture, suitable for many customers. However, if you do not clean often stainless steel sink will quickly be turned to silver with a layer of aesthetic yellow residue.
    Porcelain sink
    If you are wondering, choosing porcelain sinks is a great choice for you. High gloss natural porcelain material that exudes luxury and value for your kitchen. Moreover, porcelain is easy to clean, clean, dusty or greasy. Nowadays, porcelain sink pots are very diversified and colorful, and homeowners can choose.
    However, when choosing porcelain sinks you should also note that this material is also prone to scratches if sharp objects work.
    Stone sink
    Similar to porcelain sinks, the stone also looks beautiful shiny natural, bringing modern space to your kitchen. In addition, the stone is waterproof, no holes for bacteria to stay away from grease. So many families choose to design stone sinks.
    Hopefully with this information you will select the sink suitable for your kitchen. Sinks of porcelain, stainless steel or stone should be appropriate and balanced with the kitchen interior and financial ability of the family.
    See more: http://learncookingus.com/todays-dem...y-in-a-faucet/
  • sancho
    • Mar 2015
    • 301
    Hello sage12
    You can use the item proc_info
    For example:
    proc_info[chrome.exe,wkset,sum]
    to find memory usage of all processes of Chrome
    I hope it helps you.
