Zabbix Configuration Help
  • userx
    • Mar 2014
    Hi Techs
    I managed to install my Zabbix server and I can access the web portal but after adding clients to be monitored by the system,i dont see them though the zabbix agent is running on the machines.I have configured the conf and i think thats where I messing up some stuff.I really need to be helped on this.
    Regards
  • steveboyson
    • Jul 2013
    • 582
    The host names defined in the web frontend must match the name defined in the agent's config file.
    • userx
      • Mar 2014
      Zabbix Configaurations
      Hi
      Thanx for the quick reply,If you can please send a me an example of a Conf. file thats working to cross check with the one I got that'll be so helpful,I am a newby on working with zabbix system and I have been tasked to research and implement it at my new job.
      • aib
        • Jan 2014
        • 1615
        zabbix_server web frontend:
        - Hosts -> Host name : hostname_of_client
        zabbix_agentd.conf on CLient's PC/server
        # grep -i hostname /etc/zabbx/zabbix_agentd.conf
        Hostname=hostname_of_client
        Sincerely yours,
        Aleksey
        • userx
          • Mar 2014
          Zabbix Configurations
          Thanx again for that response,I am running a windows host and it looks like that conf file is linux based..
          • steveboyson
            • Jul 2013
            • 582
            The windows agent has an identical formatted config file. Just look for a zabbix-agentd.conf file when you installed the agent.
            • aib
              • Jan 2014
              • 1615
              and don't forget to restart Zabbix Agent service every time when you change the configuration.
              OK?
              Sincerely yours,
              Aleksey
              • tchjts1
                • May 2008
                • 1605
                I think in most cases the file name is zabbix_agentd.conf file (underscore instead of a hyphen)
                • steveboyson
                  • Jul 2013
                  • 582
                  True! (except on Suse ;-)
                  Don't really know who had the glorious idea of changing binary and config file names between distributions.
                  • userx
                    • Mar 2014
                    This is how I have configured my config. file and I am still failing to get this host on the frontend
                    server=<http://192.168.1.2>
                    sourceip=192.168.1.114>
                    # Allow remote commands for reactive monitoring
                    EnableRemoteCommands=1
                    #Log all remotely executed commands
                    LogRemoteCommands=1
                    # Increase default timeout from 3 seconds
                    Timeout=5
                    # Increase default number of agents from 3
                    StartAgents=5
                    • tchjts1
                      • May 2008
                      • 1605
                      Server= should simply be the IP of your Zabbix server. Get rid of "http://"
                      Also, if you are using any active checks for your items, you should have ServerActive= and that should also be the IP of your Zabbix server.
                      Zabbix uses a lot of case sensitive parameters. Is your conf file server= or Server=? It should be Server= and ServerActive=
                      Also, try it without using SourceIP parameter.
                      (Edit) Oh, and don't have <> around your IP's. It should just look like Server=192.168.1.2
                      • steveboyson
                        • Jul 2013
                        • 582
                        The name specs must not contain "http" or the like. Just a name (and if it's the server address, an IP address is valid, too).
                        Oh: and don't mess with "sourceip" unless you have to. It sets the source address
                        • userx
                          • Mar 2014
                          Hi Guys
                          Thanx for the help,After making all the configurations I am getting the following error code / message
                          (ZBX_TCP_READ) failed : [0x0000274C] a connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host failed to respond)
                          • steveboyson
                            • Jul 2013
                            • 582
                            Increase the timeout values in the config files for both agent and server.
