Graphs beginning at 0?
  • weasel
    • Jul 2006
    • 15
    Hi Folks!
    zabbix is working now and it's great!
    Now I have only one problem...
    For example the server load graph will be much more meaningful if the Y axis always begins at 0 I think.
    So how can I always get the beginning of the Y to 0. Can the graphs "scale"?
    I hope you understand what I mean - if not I'll make a scrennshot
  • mbrijun
    • Mar 2006
    • 63
    Hi weasel,
    glad to hear you managed to get it running.
    To make the graph look like you want you have to create a graph with the Y axis "Fixed" instead of "Calculated". Go to Configuration > Graphs > Create graph, then put all the info, and choose the Fixed Y axis. That should be it.
    • weasel
      • Jul 2006
      • 15
      Hi mbrijun
      Yeah... that was my idea too
      The problem is that the load can be from 0 to 200 - in theory
      When I set the max to 10 the graphs will look nice and show the information I need. Every load over 10 will disappear...
      Max to 200: the graphs are way to smaaaaaaaaaall
      Any ideas for a solution?
      Thanks in advance
      • mbrijun
        • Mar 2006
        • 63
        not really sure it has that flexibility... what about setting the max value somewhere in the middle - say you know that 99% of time it does not go above 50.
        • weasel
          • Jul 2006
          • 15
          okay... no problem. I'll try to habituate with that BUT
          I'd like to set a fix value for the duskusage. The problem is that the max field only accepts double...
          it can't be that the highest value is 99KB
          pleeeeeeease... help :P
          Target: range from 0 to 300GB
          • themons
            • Feb 2005
            • 110
            I am also intersted by a solution.
            Zabbix 1.8.3
            SLES 11 x64
            French Zabbix user
            • sid
              • Jul 2006
              • 44
              You could have two graphs, one above the other. The one below has values from 0 to 100 and the one above values 100 to 200. Then you put them both on one screen and you can select the sizes. Probably not the simplest but it will show your data. And try scaling if necessary.
              • themons
                • Feb 2005
                • 110
                I have a solution
                its no very clean but ...
                On each server i make a ping wich value is 0 or 1. I had this value to the graph. the graph will start at 1 (or 0) so can easily evalute the amount of memory on the servers.
                Zabbix 1.8.3
                SLES 11 x64
                French Zabbix user
                • pdwalker
                  • Dec 2005
                  • 166
                  set your y axis to 0
                  I liked having the scaleable graphs start from 0.
                  Quick fix:
                  in frontends/php/include/classes/graph.inc.php, search for
                  function calculateMinY($side)
                  as the first line of the function, add in
                  return 0;
                  Warning: this might break your graphs if you have fixed scale graphs. I don't know, as I have not tested it on any fixed scale graphs. It restores the feature I needed, so that's good enough for me for now.
                  - Paul
                  PS: back up your file before making changes
                  • sgoodliff
                    • Jul 2005
                    • 20
                    The graphs on 1.1beta2 on my setup do start at 0, but 1.1.1 and 1.1.2 both have show some graphs that start higher up the scale.
                    • pdwalker
                      • Dec 2005
                      • 166
                      As far as I know, the change was recent.
                      The file I mentioned above actually has the line
                      // return 0;
                      at the top of the function. Just uncomment it if you want that behaviour.
                      A "proper" fix would be to add an option to make it "optional", either globally or per graph.
                      - Paul
