cpu load extract on router one access
  • Korirwn
    • Sep 2018
    • 16
    Hello people,
    I have a router one acces and i want to extract the cpu load. It's not possible to install the Zabbix agent or i don't find the way.
    Which is the best solution?
    Thank you .
  • Atsushi
    • Aug 2013
    • 2028
    There is a method of enabling the SNMP agent function of the router and monitoring from Zabbix using SNMP.
    To check whether SNMP can be used, please check the manual of the router.
    • Korirwn
      • Sep 2018
      • 16
      Yes, Thanks
      Ok I use already Snmp so that's ok for me, i just want to know if there's a best solution
      • Atsushi
        Atsushi commented
        The best solution will be different depending on manufacturer, model, firmware version.
    • Korirwn
      • Sep 2018
      • 16
      Thank's all
