SELinux and Zabbix ..
  • Nothing497
    • Aug 2013
    • 15
    Hello there,
    I'm trying to make a fresh install of Zabbix :
    - CentOS 7 / Zabbix-Server 4.0
    No problems so far, I use the "From packages" method.
    Now I'm facing the real issue : SELinux ...
    When I disable it and restart the machine, the agent of zabbix-server itself has no trouble to fetch the data.
    But I would like to let SELinux activated, and I'm trying to follow some workarounds I found on the web (apparently no official guidelines in the zabbix wiki)
    By the way, I know nothing about SELinux ... Pretty much like John Snow.
    So I create the following text file "zabbix_agent_setrlimit.pp" :
    module zabbix_agent_setrlimit 1.0;
    require {
        type zabbix_agent_t;
        class process setrlimit;
    #============= zabbix_agent_t ==============
    allow zabbix_agent_t self:process setrlimit;
    [root@VZABBIX ~]# semodule -i zabbix_agent_setrlimit.pp
    libsepol.module_package_read_offsets: wrong magic number for module package:  expected 0xf97cff8f, got 0x75646f6d (No such file or directory).
    libsemanage.semanage_pipe_data: Child process /usr/libexec/selinux/hll/pp failed with code: 255. (No such file or directory).
    zabbix_agent_setrlimit: libsepol.module_package_read_offsets: wrong magic number for module package:  expected 0xf97cff8f, got 0x75646f6d
    zabbix_agent_setrlimit: Failed to read policy package
    libsemanage.semanage_direct_commit: Failed to compile hll files into cil files.
    semodule:  Failed!
    I have absolutely no idea on how to make this work... If someone has implemented Zabbix on a machine running SELinux could help me, I would be very grateful
  • ingus.vilnis
    • Mar 2014
    • 908
    SELinux is generating lots of messages in /var/log/audit/audit.log file.
    The idea is to look for "denied" messages and make them allowed.
    For this there are some handy command line tools.
    # yum install policycoreutils-python
    Now you can generate a custom SELinux policy file for Zabbix, e.g. zabbix_server_custom.
    # grep zabbix_t /var/log/audit/audit.log | audit2allow -M zabbix_server_custom
    You can look at the contents of the created file in the current directory.
    Load newly created Zabbix server policy module into the current SELinux policy.
    # semodule -i zabbix_server_custom.pp
    Zabbix server might not be able to start properly due to still missing SELinux rules.
    Repeat this set of commands at least three times and check the Zabbix server log after each of them. It is because every time a new SELinux rule is added Zabbix server gets a step further and gets logged into audit log. Thus it is possible to pick up new issues and add them to the custom SELinux policy.
    Remove the policy files after they have been added successfully.
    # rm zabbix_server_custom.*
    You may want to review these settings as well:
    # getsebool -a | grep zabbix
    And permanently enable them if needed:
    # setsebool -P zabbix_can_network=1
    Hope this helps.
    • Nothing497
      • Aug 2013
      • 15
      Hi Ingus,
      Thanks for your reply.
      I followed your instructions (I repeat the sequence 7 times),
      At first I couldn't start zabbix-server daemon, but now it seems that it's starting and running fine.
      But I feel like there are still things denied by SELinux :
      type=SYSCALL msg=audit(1539775642.070:1541): arch=c000003e syscall=87 success=no exit=-13 a0=55db6c8f0a20 a1=0 a2=7f3482eb27b8 a3=40 items=0 ppid=2098 pid=2131 auid=4294967295 uid=998 gid=996 euid=998 suid=998 fsuid=998 egid=996 sgid=996 fsgid=996 tty=(none) ses=4294967295 comm="zabbix_server" exe="/usr/sbin/zabbix_server_mysql" subj=system_u:system_r:zabbix_t:s0 key=(null)
      type=AVC msg=audit(1539775642.073:1542): avc:  denied  { unlink } for  pid=2132 comm="zabbix_server" name="zabbix_server_preprocessing.sock" dev="tmpfs" ino=19182 scontext=system_u:system_r:zabbix_t:s0 tcontext=system_u:object_r:zabbix_var_run_t:s0 tclass=sock_file
      type=SYSCALL msg=audit(1539775642.073:1542): arch=c000003e syscall=87 success=no exit=-13 a0=55db6c8f0a20 a1=0 a2=7f3482eb27b8 a3=40 items=0 ppid=2098 pid=2132 auid=4294967295 uid=998 gid=996 euid=998 suid=998 fsuid=998 egid=996 sgid=996 fsgid=996 tty=(none) ses=4294967295 comm="zabbix_server" exe="/usr/sbin/zabbix_server_mysql" subj=system_u:system_r:zabbix_t:s0 key=(null)
      Do I have to repeat this set of commands again ? Until there is nothing denied in /var/log/audit/audit.log ?
      Or is there something to do with mysql / mariadb ?
      In addition, the frontend looks like it's trying to get data but it's also denied
      These settings looks good to me :
      [root@VZABBIX ~]# getsebool -a | grep zabbix
      httpd_can_connect_zabbix --> on
      zabbix_can_network --> on
      [root@VZABBIX ~]#
      Again, thank you for your help.
      • ingus.vilnis
        • Mar 2014
        • 908
        Did you look at what is in zabbix_server.log file?
        For that one audit error you can run:
        restorecon -R -v /run/zabbix/zabbix_server_preprocessing.sock
        But for the frontend errors no idea as I can't see what is in that screenshot. Better paste it as text.
        • Nothing497
          • Aug 2013
          • 15
          Woops sorry about that, here it is :
          [LIST][*]session_start(): open(/var/lib/php/session/sess_npqd9riighne7qgba5ob40tpg4, O_RDWR) failed: Permission denied (13) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->__construct() → CSession::start() → session_start() in include/classes/core/CSession.php:49][*]session_write_close(): open(/var/lib/php/session/sess_npqd9riighne7qgba5ob40tpg4, O_RDWR) failed: Permission denied (13) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->__construct() → CSession::start() → session_write_close() in include/classes/core/CSession.php:53][*]session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/session) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->__construct() → CSession::start() → session_write_close() in include/classes/core/CSession.php:53][*]session_start(): open(/var/lib/php/session/sess_npqd9riighne7qgba5ob40tpg4, O_RDWR) failed: Permission denied (13) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerDashboardView->checkInput() → CController->validateInput() → CSession::keyExists() → CSession::open() → session_start() in include/classes/core/CSession.php:138][*]session_write_close(): open(/var/lib/php/session/sess_npqd9riighne7qgba5ob40tpg4, O_RDWR) failed: Permission denied (13) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerDashboardView->checkInput() → CController->validateInput() → CSession::keyExists() → CSession::close() → session_write_close() in include/classes/core/CSession.php:149][*]session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/session) [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerDashboardView->checkInput() → CController->validateInput() → CSession::keyExists() → CSession::close() → session_write_close() in include/classes/core/CSession.php:149][/LIST]
          EDIT : No more audit error after running
           # restorecon -R -v /run/zabbix/zabbix_server_preprocessing.sock
          Thanks !
          EDIT 2 : It seems that httpd is denied by SELinux :
          type=SYSCALL msg=audit(1539780188.206:696): arch=c000003e syscall=2 success=no exit=-13 a0=7fffecebd880 a1=42 a2=180 a3=0 items=0 ppid=976 pid=1842 auid=4294967295 uid=48 gid=48 euid=48 suid=48 fsuid=48 egid=48 sgid=48 fsgid=48 tty=(none) ses=4294967295 comm="httpd" exe="/usr/sbin/httpd" subj=system_u:system_r:httpd_t:s0 key=(null)
          type=PROCTITLE msg=audit(1539780188.206:696): proctitle=2F7573722F7362696E2F6874747064002D44464F524547524F554E44
          type=AVC msg=audit(1539780188.206:697): avc:  denied  { read write } for  pid=1842 comm="httpd" name="sess_npqd9riighne7qgba5ob40tpg4" dev="dm-0" ino=415943 scontext=system_u:system_r:httpd_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=file
          type=SYSCALL msg=audit(1539780188.206:697): arch=c000003e syscall=2 success=no exit=-13 a0=7fffecebd9e0 a1=42 a2=180 a3=1 items=0 ppid=976 pid=1842 auid=4294967295 uid=48 gid=48 euid=48 suid=48 fsuid=48 egid=48 sgid=48 fsgid=48 tty=(none) ses=4294967295 comm="httpd" exe="/usr/sbin/httpd" subj=system_u:system_r:httpd_t:s0 key=(null)
          type=PROCTITLE msg=audit(1539780188.206:697): proctitle=2F7573722F7362696E2F6874747064002D44464F524547524F554E44
          • ingus.vilnis
            • Mar 2014
            • 908
            Do the errors go away with SELinux in permissive?
            setenforce 0
            And reload the page?
            Could be this one: https://stackoverflow.com/questions/...es-are-created
            • Nothing497
              • Aug 2013
              • 15
              Yes indeed !
              But no luck with these commands :
              [root@VZABBIX ~]# restorecon -v "/var/lib/php/session"
              [root@VZABBIX ~]# semanage fcontext -a -t httpd_sys_rw_content_t /var/lib/php/session
              [root@VZABBIX ~]# systemctl restart httpd
              [root@VZABBIX ~]#
              • ingus.vilnis
                • Mar 2014
                • 908
                Then search audit log for the php session directory and try to create a policy in the same manner as you did for Zabbix server.
                Or search for best SELinux practice for your web server and php version. There were articles on the same permission topic, you might find your answer there.
                • Nothing497
                  • Aug 2013
                  • 15
                  Apparently I solved this last problem by executing these commands :
                  [root@VZABBIX ~]# grep httpd_t /var/log/audit/audit.log | audit2allow -M httpd_custom
                  ******************** IMPORTANT ***********************
                  To make this policy package active, execute:
                  semodule -i httpd_custom.pp
                  [root@VZABBIX ~]# semodule -i httpd_custom.pp
                  Thank you very much Ingus !
                  • ingus.vilnis
                    • Mar 2014
                    • 908
                    Awesome! You did it! Good lesson learned.
                    • Nothing497
                      • Aug 2013
                      • 15
                      Yep, I'm not sure of what I just allowed by running this, but it's working !
                      Hopefully I'm done with the setup of SELinux. Cheers !
                      • nibble
                        • Jul 2019
                        If your service " zabbix-agent.the service " is not started after rebooting the system with enabled selinux:
                        semanage permissive -a zabbix_agent_t
                        • davood
                          • Feb 2022
                          Hi
                          it works for centos 7 and zabbix 5, but it dosent work on zabbix 6 and rocky 8.5. what can I do?
                          it doesn't work yum install python-policycoreutils because install: missing destination file operand after 'python-policycoreutils'
                          Try 'install --help' for more information.
                          I used it yum install python3-policycoreutils but when I I can't run grep zabbix_t /var/log/audit/audit.log | audit2allow -M zabbix_server_custom because -bash: audit2allow: command not found
                          • Atsushi
                            Atsushi commented
                            Isn't it policycoreutils-python-utils instead of python-policycoreutils?
                            # dnf install policycoreutils-python-utils
                        • davood
                          • Feb 2022
                          Thanks a lot. I used # dnf install policycoreutils-python-utils and fixed the problem. Thank you so much.
                          why we must use # dnf install policycoreutils-python-utils?
                          • Atsushi
                            Atsushi commented
                            On CentOS 7, I think it was a package called policycoreutils-python. As the OS version goes up, the package configuration and name may change.
