Dashboard: Last 20 issues always empty
  • abosio
    • Jun 2013
    Hello all,
    What is the exact meaning of the "Last 20 issues" in the Dashboard?
    I have some triggers which fire up and shortly after the "problem" is solved.
    In Monitoring>Triggers I can see the fact that the trigger fired up, and its actual status OK.
    In Monitoring>Events I can see the two events related to that trigger, one with status "PROBLEM", the other one with status "OK".
    In the Dashboard I can't see anything in the "Last 20 issues". Is this correct?
    Does this box show only the currently active "problems"?
    Bye,
    Andrea
  • coreychristian
    • Jun 2012
    • 159
    You are correct.
    For the last 20 issues, it appears to me that it only shows the last 20 issues that are still in a problem state.
