Check daemon status via systemctl
  • Florius
    • Jan 2017
    • 15
    I have CSF running, and this won't work with proc.num, as it doesn't have a process running.
    So I'd like to check via systemctl.
    I already have a script which gives this output:
       Active: active (exited) since Fri 2018-09-21 17:01:14 CEST; 3 weeks 6 days ago
    Is it possible to do something that if it's anything else but 'active (exited)' it triggers?
    Thank you!
  • ewestdal
    • Jul 2016
    Florius,
    I would use a system run to either run the script or execute the command directly. If you build the return of 1 or 0 into your script then you can alert based off numeric values instead. Essentially make you script check for the Active to be there or not.
