Zabbix Graph
  • vrtareg
    • May 2006
    • 293
    Zabbix Graph
    Hi
    I want to create graph with the 2 items.
    One of the items is periodicaly changed. Another one not changing for the long time or not changing at all.
    For example i have 200 licenses for some feature and i controls the used licenses quantity.
    Another example: i have 2 items to monitoring memory on server. One item checks Total Memory, another one checks free memory.
    It will be usefull to allow add item as text field to graph. If i control 2 items which shoing the same parameter but in very different ranges the graph loks not informative.
    You can look to attached images.
    On the second one the total item can be showed as text line.
    Regards
    Areg
