External link to a map
  • vali
    • Oct 2018
    Hello everybody!
    I'm new to the Zabbix community and I'm trying to get a link to a Zabbix map to include it in a Sharepoint iframe.
    I tried with zabbix/map.php?sysmapid=2 but only get a json file
    Is there a way to get a link to the map, but without the Zabbix menu, just the image? Maybe a link to the image?
    I'm using appliance ver. 4.0,
    Thank you very much!
  • vali
    • Oct 2018
    According to online manual:
    Network maps can be referenced by both sysmapid and mapname GET parameters. For example,
    http://zabbix/zabbix/maps.php?mapname=Local%20network will open the map with that name (Local network). If both sysmapid (map ID) and mapname (map name) are specified, mapname has higher priority.
    So, if I take a MAP example from Zabbix Online. eg: https://zabbix.org/zabbix/zabbix.php...w&sysmapid=159
    and change according to the manual, I get: https://zabbix.org/zabbix/maps.php?sysmapid=159
    but... i get Error 404. Object not found.
    What did I do wrong? Please help me as I try for 2 days to find the solution ...
    • zux
      • Sep 2018
      • 97
      I think the documentation needs updating. You can probably use the link in the format from your first link.
      • vali
        • Oct 2018
        Thanks for the reply!
        The main issue with the first link is that I do not want the menu to appear in the iframe.
        However, reading the announces I saw that in version 4.0.1 RC1 / 4.2 was added the possibility to activate the kiosk mode by a URL parameter. Details are here.
        It's exactly what I was looking for, I' ve tested it and it works perfectly.
        Thank you!
