PSK, does it have to be unique PSK per agent?
  • Clontarf[X]
    • Jan 2017
    • 80
    As the title says, the documentation/wording on configuring PSK isn't clear to me. Maybe I can't read very well
    https://www.zabbix.com/documentation...re_shared_keys
    It is a user responsibility to ensure that there are no two PSKs with the same identity string but different values. Failing to do so may lead to unpredictable disruptions of communication between Zabbix components using PSKs with this PSK identity string.
    So, can I not have two hosts in Zabbix which both are configured with the following;
    Host A
    PSK identity: PSK001
    PSK: 1234....
    Host B
    PSK: 1234...
    Which of the above would I need to change? Does each host need a unique identity? Does each host need a unique PSK? Or does each host require unique values for both?
  • zux
    • Sep 2018
    • 97
    PSK identity needs to be unique, the PSK probably should be, but i think it can work if it's not.
    • Clontarf[X]
      • Jan 2017
      • 80
      Thanks, so for each installed Zabbix Agent, I could configure the PSKIdentity to be something like "{$HOST.NAME}PSK"?
      • rodajrc
        rodajrc commented
        Hey, did you managed to do what you said? Using macros or anything variable in the PSKIndentity parameter? I'm having issues with this and I can't find the way to do what you said.
    • solution
      • Jun 2020
      • 272
      ...to ensure that there are no two PSKs with the same identity string but different values...
      You can use the same PSK on ALL Hosts if the PSK Identity and Value are the same.
      example:
      Works: Same PSK Identity and Value
      HostA
      PSK Identity: PSKAAA
      PSK Value: 12345
      Host B:
      PSK Value: 12345
      does not work: Same PSK Identity but Different Value
      HostA
      PSK Value: 12345
      Host B:
      PSK Value: 67890
      In my environment I use the same PSK on all Hosts and have never had any problems.
      Wellington
