Set trigger on a single character
  • Starko
    • Aug 2012
    • 93
    I have an item which returns three different characters: z / g / n
    z is fine.
    n & g are wrong
    So I wanted to write something like:
    {server.domain.local:vfs.file.contents["C:\Folder\Item.txt"].last(0)}#z
    So the Trigger goes PROBLEM everytime the letter in the text file is not z.
    The textfile gets generated every 60 seconds.
    But I think my expression only works for numbers. What do to with a single letter?
    Thank you!
  • steveboyson
    • Jul 2013
    • 582
    Why not just test for the "OK" string?
    {server.domain.local:my_item.str("z")#1}
    means: trigger fires if string "z" is not found.
    • Starko
      • Aug 2012
      • 93
      It worked, but I had to write it a little bit different:
      {server.domain.local:vfs.file.contents["C:\Folder\Item.txt"].str(z)}#1
      Thank you very much!
