Log item - PCRE works on RegExr.com but not in zabbix admin regex test / item
  • k_andersen
    • Oct 2018
    Hello
    Being fairly new to both regex and zabbix, i've run into trouble with the zabbix log file item.
    I have a regex which finds a line where my program starts and also returns the previous line.
    Its used to monitor if the program was shut down properly before being started again.
    I've verified that the regex (global) finds both lines that i am looking for on regexr.com
    e.g. in the sample log data below:
    01/10-18 00:10:23:885 TankMeasureCom v4.9.1 shut down...
    01/10-18 00:13:19:622 TankMeasureCom v4.9.1 started...
    and
    01/10-18 00:14:12:639 blabladdd
    01/10-18 00:14:13:639 TankMeasureCom v4.9.1 started...
    However I can't get zabbix RegEx test (under admin/regex) to work.
    Neither (of course) the actual log item in zabbix, posted below for reference.
    Type: Zabbix agent active
    Key:
    log[c:\progra~1\ok3\drift\logfiles\TankMeasureComLog.txt,"(.*)\n.*TankMeasureCom.v[0-9].[0-9].[0-9].started.*",,,,\1,]
    Type of info: Log
    If there is a kind soul out there that would lend me some assistance I'd be most grateful.
    My RegEx:
    Sample log data:
    01/10-18 00:09:34:760 blablalba
    01/10-18 00:10:22:745 blablalba
    01/10-18 00:13:19:825 blablalba
    01/10-18 00:13:19:841 blablalba
    01/10-18 00:14:19:936 blabla
    01/10-18 00:14:19:951 blabla
    Online example:
    https://regexr.com/42alr
    Edit #1 - I'm using zabbix 4.0
    Edit #2 - Replaced example data with real life data after Chew.Young correctly pointed that out.
    Edit #3 - Updated regexr example with new name
    Cheers Kurt
  • Mike2K
    • Oct 2018
    • 60
    Does zabbix read all the log lines properly if you omit the regex ?
    • k_andersen
      k_andersen commented
      Yes it does
  • chew.young
    • Oct 2018
    first of all, you log key did not match your sample log data (TankMeasureCom VS MyProgram). And how the trigger is defined?
    • k_andersen
      Chew, I made a mistake in trying to generalize the example data and forgot to rename TankMeasureCom in the example RegEx above.
      However the real life data is with the name TankMeasureCom, and still persists as originally described.
  • chew.young
    • Oct 2018
    How is trigger defined?
    • k_andersen
      There is no trigger. I just made the log item so i would capture the data. I would define the trigger afterwards.
      Is this the wrong approach ?
      Edit: My problem i still that i don't get any data into zabbix server - should i provide agent log details ?
