Zabbix 2.2 comes with a default set of low level mounted file system discovery in the linux OS template and the linux SNMP Disk template.
While theses are cool, they are not practical for my environment. I have hundreds of servers that all use the same nfs mounts. If one is running low on disk space I get alerts on hundreds of servers.
I would like to discover specifically only local mounted storage for the zabbix agent template and the snmp template.
