aggregate agent grpsum help
  • zozo
    • Nov 2012
    I have create an item for the asterisk calls called asterisk.calls which I am using to create graphs for the number of calls on each server.
    I would like to use grpsum to get the information from all asterisk servers and show the number of total calls in a graph. I would like to know if the format I am using is correct and where should I create this item.
    the key I am using looks like this:
    grpsum["Production","asterisk.calls","last","0"]
    thank you in advance for your suggestions
  • zozo
    • Nov 2012
    I have created an items into the zabbix_linux template where the asterisk.calls is but after some times the servers on which is assigned they are getting Not supported. Is there any help or suggestions?
