How to reference auto registered agents?
  • scott80
    • Oct 2018
    I'm new to zabbix, any help would be appreciated on what I'm assuming is a simple task.
    I have a configuration setup for zabbix agents to auto register to the server, with an empty host group prior to the agents connecting it.
    What I can't work out is how I reference the hosts within the host group for different checks that require this (e.g. the graph widget on the front dashboard).
    Is there any easy macro/item that I'm not aware of to reference auto-registered hosts within a host group?
    Thanks for any help
