1 front-end in every proxy ?
  • alessct
    • Oct 2018
    Hi, as a new user on proxmox i have one question to have an answer of it. Basically, with one zabbix server, some zabbix agents and some zabbix proxies, both (agents and proxies) in different locations, it could be relevant or make any advantage having 1 front-end in every zabbix proxy? Or maybe having 1 front-end in every proxy is ineficient and usseles ?
    Thx!
  • Atsushi
    • Aug 2013
    • 2028
    The front end for Zabbix is connected only to the Zabbix server.
    The Zabbix proxy has no front end and all monitoring data is aggregated on the Zabbix server.
    If you want to limit the hosts that can be accessed by the user, create a host group with the units you want to restrict access to.
    Then, please set the access authority for that host group to the user group.
