Obtaining values from zabbix database
  • sage12
    • Sep 2018
    How to effectively remove stink sink at home
    You feel uncomfortable when you touch the smell from the sink in the family
    friend. Dishwashing bowls are not just washed water every day to keep clean and clean. If
    Like to sink the bowl for too long without being cleaned, the handle will produce a very unpleasant odor.
    After a long process of use, the sink drainage system in the kitchen area is very stinky.
    unpleasant odor, gas smell, rotten egg smell, socks smell, smell of grease or odor of long-term impurities
    during decomposition. However, most of us are unaware of why the drainage pipes are sinking
    wash the dishes smell? or how to remedy sewage smelly? So today's article we
    I would like to advise you on how to overcome the odor of sink drainage sink. After a long time use
    The sink, you discovered that the sink of your home is emitting a stench.
    So where does the drain of the sink have a bad smell?
    This is the result of the decomposition of wastes under the sink drainage line, the smell of eggs
    or smells that you smell are an odor mix consisting of methane, hydrogen sulfide, ammonia
    and other chemicals and they cause very unpleasant odors.
    Not only stinky sink drain lines often stink, but often suffocation.
    This situation is not difficult to explain because the sink area is responsible for waste disposal
    in the process of housework of the sisters. The housework of the sisters always take place daily, the process of preliminary processing
    food or dishwashing after each meal has discharged into the sewer drainage line an amount of grease
    Overloaded with food waste, excess rice soup ...
    This habit has repeatedly led to:
    The amount of waste beneath sewer sump sewers increases without timely decay resulting in foul odors.
    Fatty oils have very high adhesion, when discharged into the sewer drainage only partially float out, the rest
    Still clinging to the drainage wall, food debris as well as the waste that goes by, entangled in oil
    the fat and stick in the pipe wall.
    At low temperatures, dry grease stains the pipe, causing sewer pipes to drain
    Unoccupied, leading to the sink and sink drainage foul smell.
    Troubles can be encountered when the sewer sink has a foul odor.
    - smell sewage drain sink up, if smells less then okay but if smelly and frequent
    Can cause eye irritation, cough, headache, dizziness and nausea.
    - For infants if the severity can lead to health effects.
    When the sewer drain is emitting a foul odor, it is also a sign of a sink blockage, which will
    interrupting the housework process of the sisters.
    - If you do not find a way to sink the sink, remedy the smell of sewer sink drain can be drained.
    Your kitchen sink drain will be the place to spread many pathogens.
    Effortlessly remove smell of sink bowl, simple cup, easy to do.
    Warm water and cleansing liquid.
    The first step in cleaning the dishwasher is to clean the leftover food scraper, which is a simple step
    will support the next step. You follow these steps:
    Cover the drainage hatch in the sink, drain hot water into the sink so that water rises to about 5
    - 8 cm. Add a little sink of soap to the hot water.
    Open the sink lid and let the water flow through the filter basket.
    If you feel the basket of food in the sink still smells and cling to food, clean the basket
    with "magic triad" ice capsule, granular salt and lemon peel. Do the following:
    Slice some ice cubes and salt into the filter basket. These stones will push the food debris out of the water
    The bar of the filter basket, and the salt will rub on the edges. For best results, you pass hot water through a filter basket
    Once again, add some lemon peel to the basket. In this way you will also smell odors.
    When you start to make ice, you put the water in the mold and add a piece of lemon in. After the water has frozen, you have
    lemon stone Putting these lemon stones in the filter basket for a while will help you to eliminate the smell
    Products.
    Vinegar and ice:
    To do the deodorant with dishwashing water, you will need to make some ice cubes from vinegar and lemon. For the vinegar
    In the ice tray, add some lemon in the ice tray. After freezing, use these stones rub
    close to the food filter basket. Brush the brush.
    To get rid of the smell in the sink, you'll need 1 cup of baking and 2 cups of vinegar. Sprinkle baking soda into the sink
    cup, then pour the vinegar over. Initially, this mixture will bubble up, leaving you alone for a few minutes. Continue pouring
    Or you can bake soda in the sink in advance, for about 15 minutes. Then, pour ¼ or ½ cup
    White vinegar and let stand for 15 minutes. During this time, you will also find this mixture bubbly and hear the sound
    xì xèo Continue pouring boiling water to remove the mixture of baking soda - vinegar and scum away.
    Not only the sink is clean, but the sludge or dirt in the water pipe is also clean.
    This method can also be applied to hand wash basins, wash the face in the bathroom to eliminate odors.
    Baking soda, lime juice and boiling water
    You need to prepare:
    ½ cup of salt
    ½ cup baking soda
    1 cup of vinegar
    Pour the ingredients into the sink in the order. Use the lid of the sink closed, for about 30 seconds for the
    This works together and removes stains or smells in the sink. You pour boiling water to clean the
    Dirty, you will not smell anymore.
    Here are some ways to overcome the odor from the sink that most effective over many years
    Our company has drawn experience and share with customers, hope it will be source of knowledge
    price.
    Feel the customer.
    Question 1: I want to use the service of sewer of your company do not know how the price?
    Answer: My company has suitable prices for customers such as:
    - Using gas: VND 400,000 / once.
    - Using a small wire spring machine: 300,000 VND / 1 meter to
    - Using a large wire spring machine: 400,000 VND / 1 meter to
    You can refer to the price or call the company for a direct consultation.
    Question 2: Hoa Phat Company has professional staffs. I was stuck in the tunnel
    long time. Fortunately, once you know the company through the internet. I asked the company to handle the problem. The company has
    What people survey and solve for me very quickly. The staff is very enthusiastic. I thank Hoa
    Play a lot.
    Tags: bad smell sink, sewage deodorant, lavabo deodorant, deodorant sink
    face, how to deodorize toilets, sanitary ware, wash basin, tips
    treat sewer
    See more: http://goodfood-us.com/2018/11/27/de...ve-approaches/
  • ingus.vilnis
    • Mar 2014
    • 908
    There are actually five tables for history and two for trends, depending on the data type. If you looked at "history" table only but the data was not there try looking at "history_uint" and "trends_uint" tables.
    But overall obtaining item values from DB directly is a heavy process, besides due to multiple tables the query will be far from optimal.
    Consider using Zabbix API to get the history exported elsewhere. https://www.zabbix.com/documentation...erence/history
