Help with Regex - Regular Expression adding leading zero to MAC address
  • SpaceMonkey
    • Nov 2018
    I'm monitoring a UPS with zabbix via SNMP. And when I read the MAC address i get it like 0:3:xx:xx:xx:xx i want it like 00:03:xx:xx:xx:xx. I tried it with regex formula in Regular expression with Preproscesing but I can't get it to work. My formula:
    /\b[0-9,a-f]\b/g
    works on regex101.com but not on zabbix, also I can't use the /g flag. I can't also use 0$0 because zabbix just writes 0$0 instead of 00:03:xx:xx:xx:xx
  • Mike2K
    • Oct 2018
    • 60
    Why so difficult ? Just match the entire value, assuming your check is correct:
    And then do 0$0
    Explore this PCRE (Legacy) regex for text replacement. Preview find-and-replace results, understand the pattern with regex explanations, and generate code.
    • SpaceMonkey
      SpaceMonkey commented
      That adds a zero at the beginning but I want to add 0 at all places where there is single digit, see in my example 0:3:xx --> 00:03:xx
  • Mike2K
    • Oct 2018
    • 60
    Ahh, I didn't see that, sorry for that.
    I'm not sure if preprocessing allows this form of iteration. What you could do is create a separate preprocessing rule for each block of the MAC address.
    That won't be an elegant solution but if it works...
    • SpaceMonkey
      • Nov 2018
      No problem and thank you for the idea. But that is also a part of the problem that 0$0 doesn't work as regex but like plain text. So instead of writing the MAC address it writes 0$0 in plain text on latest data tab.
      • Mike2K
        Mike2K commented
        Wasn't it something like a \0 for all matches and \1, \2 for individual matches ?
        Some reading: http://www.schatenseite.de/en/2018/0...r-expressions/
      • SpaceMonkey
        Yes \0 also works but zabbix doesn't support global (/g) flag so \0 is the same as \1 in this example because is finds 1st matching and not all. So I would still have to do it for each block.
    • Semiadmin
      • Oct 2014
      • 1626
      For example:
      • SpaceMonkey
        Thanks, it works. It's just what I was looking for.
    • SpaceMonkey
      • Nov 2018
      Thank you Mike2K and Semiadmin for help.
