Cisco Catalyst 4510+
  • Andre Gustavo
    • Nov 2018
    how can I monitoring traffic on a Cisco Catalyst 4510 interface? I read something about the interface snmp aggent corresponding is at the same order of interface. For exemple if I want to monitoring the interface Gigabitethernet number 1/1/40 I should use ifOutOctets[IF-MIB::ifDescr.40] and the interface Gigabitethernet 2/1/39 ifOutOctets[IF-MIB::ifDescr.203] ? How can I get the MIB for this device? Thanks!
  • Mike2K
    • Oct 2018
    • 60
    The standard Cisco template from zabbix should be able to do this out of the box (we have like 200 switches doing the same )
    • Andre Gustavo
      Andre Gustavo commented
      Thanks for your answer, but the template wich I have is for a 2960 and i need a 4510 Template, cos the number of ports it's very different. Can you help me, please?
  • Mike2K
    • Oct 2018
    • 60
    You should use this one: https://share.zabbix.com/network_dev...-net-cisco-ios
    That also has an lld rule for the discovery of interfaces
