centos 7.5.1804
apache 2.4.6
php 7.2.11
php-mysqlnd 7.2.11
mysql 14.14 distrib 5.7.24
1. yum -y install http://repo.zabbix.com/zabbix/4.0/rh...el7.noarch.rpm
2. yum -y install zabbix-get zabbix-server-mysql zabbix-web-mysql zabbix-agent
vvv
what is the problem??
apache 2.4.6
php 7.2.11
php-mysqlnd 7.2.11
vvv
[root@localhost ~]# Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
* base: mirror.kakao.com
* elrepo: repos.lax-noc.com
* epel: mirror.premi.st
* extras: mirror.kakao.com
* remi-php72: ftp.riken.jp
* remi-safe: ftp.riken.jp
* updates: mirror.kakao.com
Resolving Dependencies
--> Running transaction check
---> Package zabbix-agent.x86_64 0:4.0.1-1.el7 will be installed
---> Package zabbix-get.x86_64 0:4.0.1-1.el7 will be installed
---> Package zabbix-server-mysql.x86_64 0:4.0.1-1.el7 will be installed
---> Package zabbix-web-mysql.noarch 0:4.0.1-1.el7 will be installed
--> Processing Dependency: zabbix-web = 4.0.1-1.el7 for package: zabbix-web-mysql-4.0.1-1.el7.noarch
--> Processing Dependency: php-mysql for package: zabbix-web-mysql-4.0.1-1.el7.noarch
Package php-mysql-5.4.16-45.el7.x86_64 is obsoleted by php-mysqlnd-7.2.11-1.el7.remi.x86_64 which is already installed
---> Package zabbix-web.noarch 0:4.0.1-1.el7 will be installed
--> Processing Dependency: php-ldap for package: zabbix-web-4.0.1-1.el7.noarch
---> Package php-ldap.x86_64 0:7.2.11-1.el7.remi will be installed
--> Finished Dependency Resolution
Error: Package: zabbix-web-mysql-4.0.1-1.el7.noarch (zabbix)
Requires: php-mysql
Available: php-mysql-5.4.16-45.el7.x86_64 (base)
php-mysql = 5.4.16-45.el7
Available: php-mysqlnd-5.4.16-45.el7.x86_64 (base)
Available: php-pecl-mysql-1.0.0-0.17.20160812git230a828.el7.remi.7.2.x86_64 (remi-php72)
php-mysql = 1:1.0.0
Installed: php-mysqlnd-7.2.11-1.el7.remi.x86_64 (@remi-php72)
Not found
Available: php-mysqlnd-7.2.10-1.el7.remi.x86_64 (remi-php72)
Not found
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Requires: php-mysql
php-mysql = 1:1.0.0
Not found
Not found
