zabbix 4 don't check process windows problem
  • barto_95
    • Nov 2018
    • 16
    It's necessary for me to check if a process is running on windows server
    I create a template and item but I have a error (not supported and invalid first parameter)
    do you have a idea for this check work please ?
    thank you
  • batchen_regev
    • Aug 2018
    • 80
    i dont think it can check 4D by the docs i see it can only check specifics :
    try googling this :
    • Key: service.info[lanmanworkstation]
    also
    https://www.zabbix.com/documentation...ent/win_keys?s[]=windows#monitoring_windows_services
    scrool to buttom of page.
    hope this helps.
    • ArtursL
      • Nov 2018
      • 167
      You can use the proc.num key to monitor a Windows process. Example - proc.num["process name"]. What this does is it returns the number of running processes corresponding to the name you specified.
      You should then create a trigger that checks if the last received proc.num value = 0, which would mean, that the process has no running instances.
      You can read more about the proc.num item here
      In case of a Window service, you can use service.info key as described by batchen_regev above.
      • barto_95
        • Nov 2018
        • 16
        thank you for response
        In process windows it's this I can check : (screenshot) I configure my item : proc.num[4D server.exe*32]
        It's ok or not ?
        • ArtursL
          • Nov 2018
          • 167
          Try creating the item like this: proc.num["4D Server.exe"]
          Afterwards, check what's the returned item value by navigating to Monitoring - Latest Data
          It should be 1 in case of a single 4D Server instance running on your host.
          • Semiadmin
            • Oct 2014
            • 1626
            Hi, barto_95.
            Try to use tasklist command to see process name. I suppose you need proc.num["4D Server.exe"] key.
            • barto_95
              • Nov 2018
              • 16
              it's great
              tasklist : 4d server.exe
              and now on zabbix it's UP(1)
              thank's for your help guys
              • zabbixisfun
                • Apr 2019
                • 9
                Is there LLD discovery rule that we can use to discover running processes
                • jonsbtran
                  Banned
                  • Sep 2019
                  Originally posted by zabbixisfun
                  Is there LLD discovery rule that we can use to discover 192.168.1.1 router running processes
                  If so, can you inform me?
