Does Actions "Default operation step duration" works for only one operation?
  • saibuster
    • Jul 2018
    • 32
    So I have the following action operation:
Name:	step operation.JPG
    As you can see, I have only one operation. My question is, will I get 4 hours gap between each email alert or does it mean that step duration only refers to each trigger? (which unfortunately can't be time controlled)
