I need help for configure monitor in applicaions IIS
  • Caio
    • Nov 2018
    Hello, I'm new to the zabbix tool, and I need help to do an application monitoring (web site) on the IIS web server, however I do not know how to start, I have little knowledge in the tool, I need to monitor memory consumption, cpu or any other performance information in each application in the ISS, for example: site "a" consumes 10% of memory 20% of cpu, something like this example, if you need any specific information to make this type of configuration just list that I inform, thank you very much.
  • Caio
    • Nov 2018
    someone can help me?
    • kloczek
      • Jun 2006
      • 1771
      did you google for "iis zabbix template"?
      • Caio
        • Nov 2018
        Yes, however not found i need.
        • kloczek
          • Jun 2006
          • 1771
          On on first page with google search results is possible to find more than one template.
          • Caio
            • Nov 2018
            I see, however i am novice in zabbix, i need help.
            • ingus.vilnis
              • Mar 2014
              • 908
              Considering the Zabbix experience and knowledge needed for your task, having someone doing this for you would give the best results. Have you thought about approaching Zabbix Support services for this task? https://www.zabbix.com/consulting
              • Caio
                • Nov 2018
                Yes, but the value is expensive for me.
                • Caio
                  • Nov 2018
                  Someone can help me?
