Incompatibility with Zabbix 4.0
  • sherloc987
    • Nov 2018
    It looks like this is not compatible with Zabbix 4.0:
    zabbix_agentd.log
    15581:20181109:071736.686 Starting Zabbix Agent [p2vproddb.xxxx]. Zabbix 4.0.0 (revision 85308). 15581:20181109:071736.687 **** Enabled features **** 15581:20181109:071736.687 IPv6 support: YES 15581:20181109:071736.687 TLS support: YES 15581:20181109:071736.687 ************************** 15581:20181109:071736.687 using configuration file: /etc/zabbix/zabbix_agentd.conf 15581:20181109:071736.692 unsupported module "libzbxpgsql.so" version: 1 15581:20181109:071736.693 loading modules failed, exiting...
    yum info libzbxpgsql.x86_64
  • ingus.vilnis
    • Mar 2014
    • 908
    Apparently not.
    You should contact the author of the particular module.
    • kloczek
      • Jun 2006
      • 1771
      zabbix_agentd.log
      Above message says that module has been compiled for exact ABI version.
      You need recompile this module.
