Disable monitoring at specific time
  • chechu
    • Mar 2014
    I need to disable the triggering of events at a specific time (i.e: at daily reboots, etc...). Maintenance windows does't fit my necessities since we need to avoid events, even if they are marked with the Maintenance icon (Data collection but without triggers).
    I've been searching for a solution through the forum and internet and I found some workarounds that I can't afford configuring since all of them are trigger based and I need to set this at a upper level, host would be perfect.
    So, sumarrised, configure, somehow, a Host to be disabled (but with data collection) between 04:00:00 and 04:30:00.
    Thanks in advance and best regards,
    Chechu.
  • aib
    • Jan 2014
    • 1615
    The easiest way is to setup time in "When active" field for Media of User.
    Administration -> User -> (select user) -> Media -> (Edit) : When active: 1-7,04:30-04:00
    After that all events wouldn't be sent when User is not active.
    Sincerely yours,
    Aleksey
    • chechu
      • Mar 2014
      Hello Aib,
      Thanks for your reply.
      I'll have a look at that and come back to you if it worked.
      Regards.
