Another Database Question
  • cozancin
    • Nov 2012
    • 10
    For the Zabbix Database, the events table contains a field called source. This field identifies the source of the event.
    From the API documentation at https://www.zabbix.com/documentation...e/event/object, the follow sources are identified:
    Possible values:
    0 - event created by a trigger;
    1 - event created by a discovery rule;
    2 - event created by active agent auto-registration;
    3 - internal event.
    If source=0, then the event is from a trigger and objectid is the triggerid of the trigger that caused thet event.
    Does anyone know what objectid is set to for the other sources?
  • cozancin
    • Nov 2012
    • 10
    Update
    I have continued to improve my checks.
    Here is what I have so far:
    SELECT count(*) FROM events
    LEFT JOIN triggers ON triggers.triggerid=events.objectid
    WHERE events.source = '0' and triggers.triggerid is null;
    LEFT JOIN host_discovery ON host_discovery.hostid=events.objectid
    LEFT JOIN services ON services.serviceid=events.objectid
    WHERE events.source = '1'
    and host_discovery.hostid is null
    and services.serviceid is null;
    LEFT JOIN autoreg_host ON autoreg_host.autoreg_hostid=events.objectid
    WHERE events.source = '2' and autoreg_host.autoreg_hostid is null;
    3 - internal event.
    I am still tracking this one down
