LLD from json
  • ermi
    • Nov 2018
    LLD from json
    I have json like so
    "data": [
    "{#HOST}": "host1",
    "{#STATUS}": "online"
    "{#HOST}": "host2",
    "{#STATUS}": "offline"
    Host1 & Host2 are not really host per se. I can get data only from json.
    Is it possible to use LLD to automatically create items (host 1 and host2) and associate values (offline or online) to it?
    I'm able to create items but never get any values.
    I have created file /etc/zabbix/zabbix_agentd.d/vpn.conf with content: UserParameter=vpn.host.check,curl -s -k <IP address>:8080/status
    If i run: zabbix_agentd -t vpn.host.check i can get taht json, so this part should be OK.
    I created Template, discovery rule and item prototype.
    I'm out of ideas. Help needed.
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi man,
    - Use zabbix 4
    - Create regular item
    After validate received json data
    - Create a dependent items with LLD
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
