Help with a log file
  • cyberfarer
    • Apr 2014
    Greetings,
    I want to capture failied sudo attempts. I created an item that looks like this:
    log["/var/log/auth.log","sudo:auth","UTF-8",1]
    It works and I can view the sudo history in Zabbix. So next I created a trigger that looks like this:
    {host:log["/var/log/auth.log","sudo:auth","UTF-8",1].str("authentication failure")}=0
    This trigger makes all warnings go away. If I change it to this:
    {host:log["/var/log/auth.log","sudo:auth","UTF-8",1].str("authentication failure")}=1
    The warnings never go away.
    I've read the docs and searched for help but it just isn't clear to me how to capture specific log events and clear them after a period of time or after the log period expires. Any help is appreciated.
    Thanks.
  • cyberfarer
    • Apr 2014
    I think I have it.
    Item:
    log["/var/log/auth.log","authentication failure","UTF-8",1]
    Trigger:
    {host:log["/var/log/auth.log","authentication failure","UTF-8",1].nodata(30)}=0
    Found here: http://theholyjava.wordpress.com/201...th-zabbix-1-8/
