Good Day,
My zabbix version is 3.0.4 and is running on a linux server.
I have a circuit analyzer that communicates using modbus and I want to retrieve the data using zabbix (I use a USB adapter to communicate the Modbus signal to the linux server). I installed libzbxmodbus according to the guide in https://github.com/v-zhuravlev/libzbxmodbus .
The information in my circuit analyzer is stored in blocks of 2 registers, so if a I want (for example) to know the tension in L1 line I have to check the register 00 to 01 and I should receive 220.
In order to try this I execute zabbix_get -s 127.0.0.1 -k'modbus_read["/dev/ttyUSB0 N 8 1",1,0,4,I,0]' and i get 3850577681549426688
I think that my problem is that I'm checking from the register 0 to the last.
My question is:
How do i establish a block to read?
My question is:
