help sms clickatell
  • bennani
    • Mar 2014
    • 19
    help sms clickatell
    I execute this site step by step I receive the following
    error:
    /usr/lib/zabbix/alertscripts/
    cli_sms_clickatell.php: 1: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: !/usr/bin/php: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 2: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: cannot open ?php: No such file
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 3: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: /bin: Permission denied
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 4: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: zabbix-release_2.2-1+precise_all.deb: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 5: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: zabbix-release_2.2-1+precise_all.deb: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 6: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: zabbix-release_2.2-1+precise_all.deb: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 24: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: =: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 26: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: //: Permission denied
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 27: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: =: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 29: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: //: Permission denied
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 30: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: =: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 31: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: =: not found
    /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: 127: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: Syntax error: Unterminated quoted string
  • aib
    • Jan 2014
    • 1615
    Citation from your documentation:
    Use this content, changing the path to the php-binary, if necessary:
    First error message said that you don't have php-binary under /usr/bin/php
    1: /usr/lib/zabbix/alertscripts/cli_sms_clickatell.php: [B]!/usr/bin/php: not found[/B]
    Do you mind to correct the path to php-binary?
    You can easily find it using the command:
    # [B]whereis php[/B]
    php: /usr/bin/php /etc/php.d /etc/php.ini /usr/lib/php /usr/share/php /usr/share/man/man1/php.1.gz
    Sincerely yours,
    Aleksey
