How to exclude tagged events from the Problems Widget?
  • simonsonjh
    • Nov 2018
    On my dashboard, I have created a secondary Problems Widget for specific tagged events. Now I want to EXCLUDE these same tagged events from my primary Problems Widget. I do not see how to configure the tags in the Problems Widget to exclude events. Is there some indirect way to do it?
  • garic
    • Aug 2018
    • 11
    I also have the same question. Does somebody have a solution?
    • mgsj2006
      • May 2019
      So I yours, there is no way to exclude, only include. So you would have to set tags on all the triggers and filter so your Dashboard shows only specific tags.
