Count Item
  • wagnerjs83
    • Nov 2018
    • 15
    Count Item
    item A receives key "eventlog [Application ,," Warning "]
    is it possible to create item B to receive quantity of log that item A received within 1 hour?
  • ingus.vilnis
    • Mar 2014
    • 908
    • Semiadmin
      • Oct 2014
      • 1626
      Calculated item:
      count("eventlog[Application ,," Warning "]",1h,".*",regexp)
      • wagnerjs83
        • Nov 2018
        • 15
        Originally posted by Semiadmin
        Calculated item:
        Error:
        Incorrect function 'count' expression. Check expression part starting from: "eventlog[Application ,,"
        Suggestion?
        • ingus.vilnis
          • Mar 2014
          • 908
          Escape the quotes inside the item key.
          count("eventlog[Application ,,\" Warning \"]",1h)
          • Semiadmin
            • Oct 2014
            • 1626
            I tried to escape quotes but forum's engine devoured slashes
            • wagnerjs83
              • Nov 2018
              • 15
              Item Application_Error
Name:	Item Application Error.PNG
              Item count log1
Name:	count log 1.PNG
              item count log 2
Name:	count log 2.PNG
              Error count log 1
Name:	error count log 1.PNG
              Error count log 2
Name:	error count log 2.PNG
              • Semiadmin
                • Oct 2014
                • 1626
                " Warning " or "Error"?
                • ingus.vilnis
                  • Mar 2014
                  • 908
                  So what does the error message say?
                  Item does not exist, right?
                  In your first screenshot you have an item monitoring ERROR, not WARNING as in original description. There must exist also an item which you later are referencing in calculated items' formula.
                  • wagnerjs83
                    • Nov 2018
                    • 15
                    lol
Name:	count log 1 Warning.PNG
                    • ingus.vilnis
                      • Mar 2014
                      • 908
                      In the calculated item formula there is a space between quotes and the word " Warning ". Could be some copy paste or form formatting issue. Remove the spaces and see if the item goes supported within some 10 minutes. .
                      • wagnerjs83
                        • Nov 2018
                        • 15
                        Formula: count("eventlog[Application ,,"Warning"]",1h,".*",regexp)
                        latest data: Incorrect function 'count' expression. Check expression part starting from: "eventlog[Application ,,"
                        • ingus.vilnis
                          • Mar 2014
                          • 908
                          count("eventlog[Application ,,\"Warning\"]",1h)
                          • wagnerjs83
                            • Nov 2018
                            • 15
                            count("eventlog[Application,,"Warning"]",1h)
                            Perfect!!!
                            Thank you very much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
