Hi all,
The short story is 2 things (using Zabbix 3.4.11):
1) I've configured a trigger to generate multiple problems, but the expression is based on multiple (3) items using an AND operation so that only 1 problem should be generated if all items match a certain value. In practice, I get 3 problems whenever the trigger is fired which i think is incorrect. Here's an example of my expression:
({My SNMP:snmptrap.fallback.regexp(SNMPv2-SMI::enterprises.88.6.3.1.1.4.1.2.3)}=1) and ({My SNMP:eventkey.strlen()}>0) and
({My SNMP:eventmessage.strlen()}>0)
2) For the problem in point 1 i actually prefer to base the trigger on only 1 item in the expression, however i need the other items in the name of the trigger. In fact, the items are one parent item and 2 dependent items based on the first. I cannot find a MACRO to get data from dependent items in a trigger name, so i used the expression as a workaround so i can write {ITEM.VALUE2}, {ITEM.VALUE3}.
Background:
I'm trying to configure Zabbix based on SNMP trapping. So have an SNMP trap item configured, which is working fine. But since each SNMP trap message is a large multi-line text message, i need to grep some stuff out of it like severity, problem type and message.
Any ideas?
Background:
Any ideas?
