{ITEM.NAME} in preprocessing not working.
  • zaicnupagadi
    • Dec 2010
    • 73
    Hey Guys,
    Glad to be back after a long time of not using ZABBIX ^^
    I perform preprocessing where I need to search for a keyword that is the same as the name of a particular item. Unfortunately, when I have something like this:
    (^"Disk 1".*)(?<= status(.*)(?= temperature) - it all works, but wit this:
    (^"{ITEM.NAME}".*)(?<= status(.*)(?= temperature) - it does not, and my item name is "Disk 1", not sure if it is important - it is a DEPENDENT ITEM.
    So in the main script I read values for all o of the disks, and later in other items I just pull information I need to each disk, getting status of the disks from particular line using regex.
    Anyone has any idea why?
    Cheers,
    J
  • Semiadmin
    • Oct 2014
    • 1625
    Hi, zaicnupagadi.
    Unfortunately, you didn't mention your Zabbix version. It's possible to use an LLD macro ({#FSNAME}, in this case) in preprocessing in 4.0. In 3.4 it's impossible.
    As for {ITEM.NAME} macro, it's not supported in preprocessing.
    • zaicnupagadi
      • Dec 2010
      • 73
      Hi Semiadmin,
      Well sheeet. I got 3.4, yesterday planned an upgrade for this/next week.
      Thank you for this!
      Cheers,
      J
