I am unable to access Zabbix Frontend after installation of every 3 components separately, each on Ubuntu 18.04 OS.
Zabbix Server is installed on 1 VM, Zabbix DB on 2nd and Zabbix Frontend on 3rd. Zabbix server is UP and can connect to Zabbix DB.
For Frontend installation did following things:
installed apache2
installed php7.2
installed zabbix-frontend-php
When I try to access to IP address of VM where is frontend i see default index.html from apache2. But when i put http://IP/Zabbix i get an error 404: Not Found
The requested URL /Zabbix was not found on this server.
After frontend installation, I noticed that I don't have "zabbix.conf" file in /etc/apache2/conf-available/ folder, instead i have "zabbix-frontend-php.conf".
What am I doing wrong?
Please help!
******EDIT******
I solved problem, but now have another one... On setup.php I am getting following error:
Cannot connect to the database.
Details
******EDIT******
Problem solved again, it was incorrect version indeed. I have 4.0.0 rc3 on Server and 4.0.2 on Frontend.
Moderator can close post
installed apache2
installed php7.2
Please help!
******EDIT******
Details
- The frontend does not match Zabbix database. Current database version (mandatory/optional): 3050162/3050162. Required mandatory version: 3000000. Contact your system administrator.
******EDIT******
