Dear all,
I've just installed a Zabbix 1.1.1 into a FC4 system. I created a simple host template with an item that do simple icmppingsec.
After that I created some hosts and link with that template, the ping works fine.
Then I want to set the update interval of this template's icmppingsec item to 300s. It is set to 300s in the database correctly! However from the Monitoring->Latest Data->Graph->500 last values history, I still found that the ping runs for every 1 minute.
Am I missing something? Or is it a bug?
Thanks,
Vincent
Thanks,
Vincent
