Zabbix Authentication
  • rafael.santos
    • Nov 2018
    Hello!
    Today I tried to configure LLDAP authentication. After testing the LLDAP configuration I changed the default authentication method from Internal to LLDAP. I logged out from the GUI and now I can't login using default authentication user (Admin) and LLDAP user.
    How can I change the authentication type back to Internal using command line on Debian?
    Please, help!
  • sancho
    • Mar 2015
    • 301
    Hello Rafael,
    Try this https://www.zabbix.com/forum/zabbix-...denied?t=49250
    I hope it helps you
    A greeting.
    • rafael.santos
      • Nov 2018
      Worked!
      Thank You sancho !
